Well, if you are using our analysis functions (from the CNiMath class), you can just pass the CNiReal64Vector into the functions.  If you are using your own analysis and need a double pointer to the data, you can just put the CNiReal64Vector in the for the double pointer.  The vectors have the ability to cast to a data pointer.
Best Regards,
Chris Matthews
