Measurement Studio for VC++
How to access data in CNiReal64Vector
I acquire data and put it in variable CNiReal64Vector and need to access the waveform data in CNiReal64Vector. How do I get the array of waveform so I can do further analysis with it.
(3,372 Views)
Well, if you are using our analysis functions (from the CNiMath class), you can just pass the CNiReal64Vector into the functions. If you are using your own analysis and need a double pointer to the data, you can just put the CNiReal64Vector in the for the double pointer. The vectors have the ability to cast to a data pointer.
Best Regards,
Chris Matthews
(3,372 Views)
You access data like this:
CNiReal64Vector v;
v.Add(23);
v.Add(24);
v(0) = v(1); // index array with parenthesis instead of brakets
(3,372 Views)
