Measurement Studio for VC++
How to control DIO with VC++
Dear master.
This is  south korea. Sorry I'm poor english.
I saw example file. but I can't found bit control (Just found byte control)
My project is  Z-stage control with step motor.
check sensor(limit)
then If true generate pulse CW (for Step motor P3.7)
        if false generate pulse CCW (for step motor P3.6)
now I can understand read data(8bit) and check one bit...
but I can't code write data(1 bit) for step motor
How can I do this...
Please help me...
(3,066 Views)
hi
i'm no pro yet, but i think you can use the following method
CNiDAQmxDigitalSingleChannelWriter :: WriteSingleSampleSingleLine( bool autoStart, bool data)
to send a single boolean sample to a single line ( as the name of the method tells you 😉
hope this helps
regard, markus
Message Edited by QuickNick on 07-04-2005 09:38 AM
(3,065 Views)
