Measurement Studio for VC++
cwnumedit repaint issue
I have written a C++ application using Visual Studio.NET. I created a docking window off of the frame window by deriving a class from CControlBar. There is a dialog with a tab control on the this docking window.
Now for the problem, one of the tab controls has a cwnumedit control on it, if another dialog passes over the cwnumedit control (i.e. moving a dialog across the screen), the cwnumedit control disappears and doesn't come back until you force windows to update it (by changing tabs or something). A regular windows textbox on the same tab control doesn't do this. Any ideas why the cwnumedit control disappears?
(3,301 Views)
Which version of the control are you using? If you are using 7.1 ( the latest one) and are still seeing the problem, could you post a small project I could take a look at?
Bilal Durrani
NI
(3,297 Views)
i had this problem with a ListControl inside a TabControl.
i solved the problem by writing a workaround in OnPaint() and called m_cListCtrl.RedrawWindow()
(where m_cListCtrl is my ListCtrl)
(3,266 Views)
