Home
Community
Discussion Forums
Most Active Software Boards
Measurement Studio for VC++
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to plot 4 components on a 3D Graph? (the 4th component is represented by color like contour)
DrObb
Member
01-28-2002
05:19 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am trying to plot 3D contour (x,y,z, data). Is is possible to do that?
0
Kudos
Message
1
of 3
(3,445 Views)
Reply
Re: How to plot 4 components on a 3D Graph? (the 4th component is represented by color like contour)
Amaury
Member
01-29-2002
01:51 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yes.
The W array will allow you to assign an intensity to each point. If you need to specify a colour you need to build a color map for values corresponding to those in the intensity array.
Hope this helps.
Amaury R.
-NI Applications Engineering
0
Kudos
Message
2
of 3
(3,445 Views)
Reply
DrObb
Member
Author
01-29-2002
02:20 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
What is the W array. Can you give me an example command? like m_3DGraph.Plot...??
Thank you
0
Kudos
Message
3
of 3
(3,445 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
