Measurement Studio for VC++
How to plot 4 components on a 3D Graph? (the 4th component is represented by color like contour)
I am trying to plot 3D contour (x,y,z, data). Is is possible to do that?
(3,441 Views)
Yes.
The W array will allow you to assign an intensity to each point. If you need to specify a colour you need to build a color map for values corresponding to those in the intensity array.
Hope this helps.
Amaury R.
-NI Applications Engineering
(3,441 Views)
What is the W array. Can you give me an example command? like m_3DGraph.Plot...??
Thank you
(3,441 Views)
