Measurement Studio for VC++
How to synchronize two analog output with USB-6353 sharing a trigger
I'm have the need to synchronize two analog output on the same device (USB 6353) sharing a trigger signal on PFI0.
The programming environement is Visual C++ , and the code I wrote is as following:
DAQmxCreateTask ("", &Ao0TaskHandle);  // is the task handle for the analog output Ao0
DAQmxCreateVoltageChan((Ao0taskHandle,"Dev1/Ao0","",-5.0,5.0,DAQmx_Val_Volts,NULL);
DAQmxCfgSampClkTiming(Ao0taskHandle,5000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000);
DAQmxCfgDigEdgeStartTrig(Ao0taskHandle,"/Dev1/PFI0",DAQmx_Val_Rising);
DAQmxCreateTask ("", &Ao1TaskHandle);  // is the task handle for the analog output Ao1
DAQmxCreateVoltageChan((Ao1taskHandle,"Dev1/Ao1","",-5.0,5.0,DAQmx_Val_Volts,NULL);
DAQmxCfgSampClkTiming(Ao1taskHandle,5000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000);
DAQmxCfgDigEdgeStartTrig(Ao1taskHandle,"/Dev1/PFI0",DAQmx_Val_Rising);
DAQmxWriteAnalgF64(Ao0taskHandle,1000,FALSE,10.0,DAQmx_Val_GroupByChannel,AOdata,NULL,NULL);  AOdata is a buffer containing a sinwave
DAQmxWriteAnalgF64(Ao1taskHandle,1000,FALSE,10.0,DAQmx_Val_GroupByChannel,AOdata,NULL,NULL);
DAQmxStartTask(Ao0taskHandle);
DAQmxStartTask(Ao1taskHandle);
What happen as result of the code is that only the Ao0 channel get the sinwave output , but not the Ao1 . It seems the two channels are not synchronized.
What is wrong in my code?
Please any help non referred to a LabView soloution , first because I'm not a LavView programmder and secondly the project impose C++ as the unique environement.
Enky
Message 1 of 1
(5,814 Views)
