Measurement Studio for VC++
PIC interface GSM modem through serial port
i am trying to build LPG Gas detector with GSM modem to send sms and infor if there is any gas leak. now my qui replay estion here:
can i replay by same message ,so that the PIC microcontroller can aknoledge device like solenoid valve to eliminate the leak by shut off the valve?
guys, see in attachment ,there is simlify circuit of the project and language commands.
(6,829 Views)
I am confused as to where National Instruments products come into this application. If you could be a little more clear about what NI products you are using and in what ways you need help I will be able to have a much better idea as to how to help.
Doug B
(6,823 Views)
