Measurement Studio for VC++
How to write a DAQmx MFC message handler?
Does anyone know how to write a DAQmx message handler?  I believe that this uses the technique of Message Maps.
I am using a PCI-6251 card.
Kevin
(4,361 Views)
Kevin,
The DAQmx C++ examples in the C:\Program Files\National Instruments\MeasurementStudioVS2003\VCNET\Examples\DAQmx\ directory should give you a good start. In particular, the ContAcqVoltageSamples_IntClk example in the C:\Program Files\National Instruments\MeasurementStudioVS2003\VCNET\Examples\DAQmx\Analog In\Measure Voltage\ directory demonstrates a DAQmx reader callback. Is this what you are looking for?
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(4,346 Views)
Hi Ryan,
  Thank you for replying to my post.  "Reader callback" is not the approach that I would like to take.  I would like to write a Windows MFC program using C++.  This type of program would use a message queue, a message loop (provided by MFC), and a message handler.  Most of the NI C++ examples are the traditional sequential programs with a main() function for a console program.
  NI has an article "An Overview of DAQ Events and Occurences."  In this article in the "MFC Notes" section it uses the message WM_NIDAQ_MSG and the message handler OnDAQMessage.  I believe ON_MESSAGE is a macro with two parameters that is inserted into the Message Map.  My guess is that this macro associates the WM_NIDAQ_MSG message with the OnDAQMessage member function.  The last step is to call the function Config_DAQ_Event_Message.
  I have followed the article, and my program compiles fine with one exception.  When I add the line Config_DAQ_Event_Message(1,1,"AI0",5,4.9.4.8,0,0,0,0, WM_NIDAQ_MSG, 0) I get the the error LNK2019: unresolved external symbol _Config_DAQ_Event_Messag@ 48.
  I think that there are some setting I am missing in Visual Studio because I get the same LNK2019 error when I add any other comand such as Init_DA_Brds.
  Any observations on the approach?
  How can I get rid of the LNK2019 error?
Kevin
Message Edited by EW on 03-17-2006 09:52 AM
(4,338 Views)
Kevin,
The Config_DAQ_Event_Message and Init_DA_Brds functions are part of the API for our Traditional NI-DAQ (Legacy) driver. It is not possible to use these in conjunction with NI-DAQmx. Additionally, your 6251 does not support use of the Traditional driver. Is there a reason that a callback is not an option? Generally, this is more efficient as it allows you to easily perform data acquisition in one thread and GUI updating in another. I know of no such Windows message equivalent for DAQmx.
Ryan Verret
Signal Generators
(4,322 Views)
Hi Ryan,
I will start to look into how to use the reader callback approach.
Thanks for your help.
Kevin
(4,296 Views)
