03-31-2011 10:49 AM
I have a macro routine that intensively plots a screen and copies the image into a file (.bmp). The macro routine keeps repeating for about 15 - 20 screen shots (images). Then the macro routine opens MSWord to insert all the pictures into a word document. For the fist time running the program, I can go through all the plotting, saving images, open up the word, insert the pictures into word with no problem. However, when I run for the second time (withouth exiting the program and re-execute the program), the plotting routine will crash. I troubleshooted the problem and found out that if I did not open the MS word
(    CNiWordApplication application;
    CNiWordDocument document = application.CreateDocument();    )
Then the software can run repeatively without the plotting routine crashing. However, if I create a document and did not go through the inserting the images, the software will crash on the plotting routine on the next run. Is there anything I should be aware of when I declare CNiWordApplication application; ? I am at my wits end here and our client is not very happy.
I will appreciate your helps.
Yajai.
04-01-2011 05:23 PM
Hi Yajai,
The first thing I would suggest is checking out this article that covers the basics of using the Microsoft Word Automation Interfaces.
Just to clarify -- when you run the program the first time, it executes as it should. When you run it again, however, it will crash during the plotting/saving process. Would you mind posting a screen shot of the error message you have been seeing? Also, what do you mean when you say you create a document but don't insert the images? Are there times in the program when it does not insert all of the images it captures in the Word document?
Stephanie R.
