Measurement Studio for VC++
I need to help writing a constructor that uses an array of pointers to a class.
Please take a look at the following code:
class Course{
public:
// Default Constructor.
Course(char *CourseName = "", char *instructor = "", char *semesterYr = "");
protected:
char *CourseName;
char *instructor;
char *semesterYr;
****The Course class provides information about a particualr course****
class Student : public Course{
public:
// Constructor.
Student(char *StudentName = "", char *SS = "", char CourseGrade = ' ',
char *CourseName = "", char *instructorName = "", char *SemesterYr
protected:
char *StudentName;
char *SS;
char CourseGrade;
static i
nt NumStudentObj;
***The Student class provides information about a particular student***
AND FINALLY THE CLASS IN QUESTION!!!!!!!
class CStats : public Course{
public:
// Constructor,
CStats(Student *StudentArray[]);
private:
int NumberOfStudents;
char CourseGradeAverage;
I need to pass an array of pointers to a Student class to the CStat constructor.
Since the Student class has inhertied data members of Course class, passing
a pointer to a Student object will be more sufficient. This constructor should
also print out the information contained in the Course & Student data members.
My instructor stated that I can use array or pointer notation.
How would I setup this function so that it outputs information stored in
the data members ?
**NOTE**
Information like the StudentName , SS#, and CourseGrade will be entered from
my main() source file.
Thanks in advance,
eejay
(4,544 Views)
eejay,
If you haven't already done so, you may wish to consider posting your question to some newsgroups that deal with C++ specific questions. You may wish to try the following groups:
comp.lang.c++
alt.comp.lang.learn.c-c++
Based on the traffic in those groups, you may be able to get an answer to your question in a short amount of time.
Good luck!
Wilbur Shen
Web Support and Operations
(4,544 Views)
