Measurement Studio for VC++
IVI COM help
刚刚接触这个概念,很想具体了解IVI-COM的具体知识,包括概念,使用范围,开发细节等等,希望获得各位的帮助,如果有manule 可以发邮件给我,zsb99@163.com,谢谢!
(7,383 Views)
Sorry for not answering in Chinese.  The fundamental architecture and how to develop/use IVI-COM drivers are all documented in the IVI Specifications, found at http://www.ivifoundation.org/Downloads/Specifications.htm   I recommend you to read them.
If you just use IVI-COM driver in your app, the minimal documents are IVI-3.1, 3.2, and some 4.x documents depending on the instrument type you use.  If you want to develop IVI-COM drivers, you should read all the 3.x documents (except for 3.10), and some 4.x documents depending on the instrument type you develop for.
Plus, some step-by-step guide documents for IVI-COM beginners can also be found at, Vektrex, Agilent, or Kikusui web sites.
http://adn.tm.agilent.com/index.cgi?CONTENT_ID=1919
http://www.vektrex.com/Support/kb/index.html
http://www.kikusui.co.jp/en/download/en/document.html#IVI-COM
Hope this helps.
Makoto
(7,372 Views)
IVI驱动使用很简单,安装agilent的ivi驱动后一般都有实例程序可供参考。
如果做驱动开发可能要专用开发工具包。Smiley Indifferent
(7,350 Views)
agilent的ivi驱动程序都带有示例。参考下。
By the way, anyone knows how to get a ivi driver sdk?
(7,351 Views)
There are two IVI-COM driver development tools I know.
VIVID (Vektrex):
http://www.vektrex.com/Products/index.html
Nimbus (Pacific MindWorks):
http://www.pacificmindworks.com/products/nimbus/Nimbus.aspx
(7,346 Views)
Thanks a lot.
In a Chinese English, 3Q(meas Thanks, 3 in Chinese is "san").
Smiley Happy
(7,338 Views)
