Measurement Studio for VC++
In running the datalgr example, I get the error NIDAQ32.dll cannot start.... then program exits. Version of NI DAQ is 6.9.2, using MS C++.
(3,467 Views)
Since this is a DAQ question more than a Measurement Studio for VC++ question, I'd recommend you repost it to the DAQ forum.
Cheers,
Azucena
(3,467 Views)
Make sure you have installed support for Visual C++. You do not need to uninstall and reinstall NI-DAQ to add this support. Simply, run the NI-DAQ Setup and select to add support for Visual C++. This should fix this error. Let me know if it does not.
Brian
(3,467 Views)
