Measurement Studio for VC++
Wrapper classes generated by VC++
I'm using Measurement Studio 6, VC++6 SP5.
I used the MS6 Add/Remove wizard to add several NI gui components to my exisiting (large) project. When I use the ClassWizard, VC++ generates wrapper classes for each of the NI controls. So, for example I must use CCWPointer (generated) instead of CNiPointer.
I also created a test app using the MS6 appwizard. This does not appear to use any wrapper classes. This gives a far neater project as it doesn't need to maintain those extra generated files and classes. I compared the .dsp's and the .dsw's, but can't find any relevant differences.
So, can I use MS6 components without generating those wrapper classes? How?
Billy.
(3,485 Views)
Ideally, you never have to use the wrapper classes when using Measurement Studio components. When you added the UI components with the Add/Remove Components wizard, you should have seen the same behavior in your large project as you did in the smaller test project. There should definitely be a difference between the two projects' files, so try doing a Save All and diffing the .dsw/.dsp files.
If for some reason you're not able to get the wizard to work, take a look at the "Manually Adding Components to an MFC-Based Project" topic in the Measurement Studio reference.
- Elton
(3,485 Views)
My project files have all the settings as described in the reference topic - "Manually Adding Components to an MFC-Based Project". These settings were added automatically by the Meas Studio 'Add/Remove' Wizard.
I also compared again against the smaller apps project files and can't see a difference in the Measurement Studio parts. My app works ok, but the wrapper classes are messy.
Any other ideas why VC++ generates wrapper classes for the Meas Studio components ?
Thanks in advance,
Billy.
(3,485 Views)
