Hy Bilal,
thanks a lot for your immediate response.
To your questions:
1- Are you using any Activex controls in the CVI application?
I can't answer this question now, it is an external application, I'll try to find it out. But some days ago a DLL-file for this application was changed/overwritten by a new version of this DLL-file. Could that be the reason?
2- Are you able to launch the CVI development enviornment fully licensed?
Yes, I can, there are no problems with compiling, linking, etc.
3- Or is this happening only with an exe?
Yes it happens only with a specific application (that with the changed DLL-file), not with other CVI - applications.
4- If you open up the license manager ( Start >> Programs >> National Instruments >> NI Lice
nse Manager ), check the status of the CVI license and see if it is enabled.
Yes, both licenses (for CVI and MeasurementStudio) are enabled, without an expiration date.
5- If this is the case, try to re-enable it.
Yes, I re-enabled the license with the existing activation code, but the problem with this specific application remains.
Best regards
Egon Derflinger
