Measurement Studio for VC++
MAX Load Problem
When I try to load the Measument and Automation Explorer 4.0 on a Windows 2000 machine, it just displays the splash screen, and doesn't get into the program.
The computer does not hang, and I can easily close it down using the Task Manager.  Have tried multiple reboots, etc, but can't get it past the splash screen.
Is there something I can do?
John
(4,367 Views)
Hi John,
Are you logged in with Administrator priviledges? If you log in as a member of the Users group, MAX can have problems accessing its configuration files.
Which service pack is Windows 2000?
You could also try these steps, however beware this will delete any DAQmx configuration that is set up on this machine:
Close MAX. Go to Control Panel>>Administrative Tools>>Services - find and stop the nidevldu (nipxirmu) service.
Terminate any National Instruments Applications and processes. Open up Task Manager and look primarily for the NIMAX.EXE and nipalsm processes. These are the most common tasks that will need to be terminated even after all the applications have been closed.
Delete all MAX data files - Warning: this step will delete all NI-DAQmx virtual channels and SCXI chasses - but it won't affect any of the traditional DAQ configuration.
Go to ..\National Instruments\MAX\Data\ and delete all of the files in this directory.
Restart the nidevldu (nipxirmu) service from the services control panel. This service can be restarted from the same place that it was stopped. Verify that all the files deleted from the ..\MAX\Data folder are created again after restarting the service.
Try restarting MAX and see if this cures the problem.
Good Luck!
Best wishes,
Mark
(4,358 Views)
