Measurement Studio for VC++
Multiple Y Axes Reference
How do I reference a plot to the second Y axis?
Using the example Multiple Y Axis....
I want Plot 2 to reference the seconds Y axis, however, it always references the first Y axis
void CMultipleYAxisDlg::OnGenerateData()
int i;
CNiReal64Vector RedData(100);
CNiReal64Vector MagentaData(100);
CNiReal64Vector WhiteData(100);
for (i = 0; i < 100; i++)
MagentaData[i] = -25;
WhiteData[i] = 125; // always references 1st Y axis on right side
RedData[i] = 700;
m_Graph.GetPlots().Item(1).PlotY(MagentaData,0,1);
m_Graph.GetPlots().Item(2).PlotY(WhiteData,0,1);
m_Graph.GetPlots().Item(3).PlotY(RedData,0,1);
(3,301 Views)
The CNiPlot class has a YAxis property whose type is CNiAxis. You should set this property to the axis that you want associated with the plot. For example, assuming your graph has at least two plots and at least two y axes, you could do this:
m_Graph.Plots.Item(2).YAxis = m_graph.Axes.Item(3);
- Elton
(3,301 Views)
