Measurement Studio for VC++
Run-Time Check Failure #2 - Stack around the variable 'NiPlots' was corrupted.
Why do I get this message box pop up in Visual C++.net with the following code when exiting the function:
void CESCView::InitGraphPower(void)
CNiPlots NiPlots;
if (m_NiGraphPower.m_hWnd)
m_NiGraphPower.PlotAreaColor = COLOR_LIGHT_YELLOW;
NiPlots = m_NiGraphPower.GetPlots();
NiPlots.RemoveAll();
NiPlots.Add();
NiPlots.Add();
NiPlots.Add();
NiPlots.Item(VIEW_PLOT_POWER_ACTUAL).SetLineColor(COLOR_BLUE);
NiPlots.Item(VIEW_PLOT_POWER_DCH).SetLineColor(COLOR_RED);
NiPlots.Item(VIEW_PLOT_POWER_REG).SetLineColor(COLOR_RED);
else
ASSERT(FALSE);
The code below runs without any problem
//C
NiPlots NiPlots;
//NiPlots = m_NiGraphPower.GetPlots();
m_NiGraphPower.GetPlots().RemoveAll();
m_NiGraphPower.GetPlots().Add();
m_NiGraphPower.GetPlots().Item(VIEW_PLOT_POWER_ACTUAL).SetLineColor(COLOR_BLUE);
m_NiGraphPower.GetPlots().Item(VIEW_PLOT_POWER_DCH).SetLineColor(COLOR_RED);
m_NiGraphPower.GetPlots().Item(VIEW_PLOT_POWER_REG).SetLineColor(COLOR_RED);
else
ASSERT(FALSE);
(3,918 Views)
Please make sure you have the Visual C++.NET update. If you do not, you can request the update from:
http://digital.ni.com/softlib.nsf/websearch/54D7F0484F7AE7D786256B900073DB48?opendocument
Mika Fukuchi
Application Engineer
(3,918 Views)
I am running the update, but still getting this error.
(3,918 Views)
