Measurement Studio for VC++
NI Controls do not run in MFC sample ViewEx
Please take a look on my previous question:
NI Controls in CFormView running in a dll applications"
I think the problem is not the dll.
Copy the sample VIEXEX from MSDN and let it run
then you see everything is ok.
When you place a NI Control via ActiveX (CW..)or Measurement Studio (CNi..) in the resource editor,
the applikation do not create the view.
Can tell my anybody why?
Juergen
(3,640 Views)
Juergen,
please check the following examples from NI homepage:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EFE056A4E034080020E74861&p_node=DZ52118&p_source=External
and
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B4B175A57C2065D6E034080020E74861&p_node=174961&p_source=External
hope it helps.
stefan
(3,640 Views)
Stefan,
I am sorry this document and example descripes the dynamic creation.
I have got a problem with static controls in Doc/View Apps. The view is derived from CFromView
If you create a test App(Doc/"Form"View) with the Wizard it works fine.
If you place the same Ni-Control in ViewEx sample it does´t work !?!
please also see the question:
greetings
Juergen
(3,640 Views)
I have a similar problem. I am creating a Dialog based MFC Application, If I include NI Controls in any of the Dialog's in my Application, That Dialog is not creation Fails.
However, I can compile and Run successfully any other similar sample application posted on this forum.
It seems to me that, It could be some compiler/project setting problem. But I can't see any differences.
Vinod
(3,640 Views)
Thanks for your answer,
This is the first time that hear that the conrtols
dont run in a Dialog
I think it would be the best to post a new question
about your problem, because this is an old one.
When it is posted a lot of developers will see it.
Maybe you can give a hint on this old question.
greetings juergen
(3,640 Views)
