Measurement Studio for VC++
TCP/IP communication slower than RS-232 using NI VISA
I'm using NI VISA 2.6 controlled by a C++ATL component.
I'm trying to debug why command-response type communication
takes apparently so much longer under TCPIP than RS-232 using the NI VISA driver.
From my application program standpoint, there is no difference between
TCPIP and RS-232 once the port is opened. I put a timer around the communication calls and and it takes 60-70 system ticks to complete using RS-232 at 38.4 kbaud. Approx 148 characters are recieved.
NISpy reports the last line in the response comes back 70-80ms after the initiating command.
Using TCPIP, the same thing takes 360-400 ticks to complete.
But using the NI spy program, it generally reports that the response comes back
in about 10ms.
Anyone have any hints on this?
(3,118 Views)
Hey Kent,
That is an insteresting problem. What VISA API are you using? The activex control, C dll, or the C++ classes.
In addition, it would really help if you could post the serial and ethernet SPY captures. It's best if both captures are doing the exact same functions.
-JoshuaP
(3,118 Views)
