04-13-2006 03:49 PM
04-14-2006 05:23 PM
It sounds like something has become corrupt in your DAQ driver. The latest version of DAQmx is 8.0.1. If you have an older version, then I recommend upgrading to the new driver. If you currently have this version, then you can repair the installtion. You can do this by going to Control Panel >> Add/Remove Programs >> NI Software >> Change >> Select "DAQmx" >> click "Modify" >> and select "Repair." Please let me know if either of these steps eliminates the problem.
Hal L.
04-17-2006 11:04 AM
I have done that already, it will work for awhile, but then the problem will come back later after several On and OFF on the machine.
I get this error message under System Event Viewer.
The NI Configuration Manager service terminated unexpectedly. It has done this 1 time(s).
Source: Service Control Manager Event ID 7034
The nidevldu service terminated unexpectedly. It has done this 1 time(s).
I cannot duplicate the problem if I disconnect the computer from the machine "without" the NI cable connected. It seems this problem can happen when I have the computer connected to the machine.
Johnny
04-18-2006 03:00 PM
Hi Johnny,
This is a very strange error. What OS do you have on this computer? If it is Windows XP, what service pack(s) do you have?
Hal L.
04-18-2006 05:00 PM
04-19-2006 05:30 PM
Hi Johnny,
Thanks for the information. Since you have repaired the driver and it didn't fix the issue, I would like you to try a full uninstall/re-install of the driver. Also, just to make sure I'm clear: you are using version 8.0.1. What hardware do you have installed on this system? Please let me know what you find out.
Hal L.
04-19-2006 06:00 PM
04-20-2006 03:08 PM
Hi Johnny,
If you have already performed these steps, then I think that we have exhausted all of our possiblities here. I recommend contacting National Instruments Technical Support directly for assistance with this issue.
Hal L.
04-20-2006 03:34 PM
I did, that was my first option.
He told me exactly what you have told me, but as you know we always need to ask for a second opinion, if the issue still pending...
Thanks a lot for your help my friend.
Johnny
12-01-2006 02:35 PM
