Measurement Studio for VC++
NI Measurement Studio AppWizard not found when starting a new project
Hi all:
Today I installed Components Works++ on my PC. Before that I had to install SP-5 for VC++. The installation of ComponentWorks++ was uneventful. Once the installation is complete and the PC was restarted, I opened VC++ application and started to create a new project. But I couldn't see NI Measurement Studio AppWizard among the project options.
1. I verified the installation of ComponentWorks and all the files are seem to be installed properly.
2. I could also see the file MeasurementStudioAppWizard.awx under C:\Program Files\Microsoft Visual Studio\Common\MSDev98\Template, which may be an indication that ComponentWorks++ was installed properly.
3. I could compile and ru
n the sample programs came with ComponentWorks++
Is there anyway I could fix this. Is there a work around for this problem?
Thanks for your time.
jkn
(3,443 Views)
With my friend's help I found the answer. My VC++ installation is on the D drive and ComponentWorks++ is putting the Wizard file on the C: Drive. When I manually moved the file to the D drive, then the Wizard showed up on the New project dialog
(3,443 Views)
