Measurement Studio for VC++
Is the VisualC NI-Daq example code correct for DIdoubleBufHandshake653x.c??
If so, why does it call Align_DMA_Buffer?? In the help documentation it says that Align_DMA_Buffer is only for the AT-DIO-32F device and digital I/O pattern generation, whereas this is supposed to be an example for a 653x device and regular handshaking. And that's another thing... why in the example does it say "Start the double-buffered pattern generation input" in the comments, when this isn't even a pattern generation example, but rather a simple dubble buffered handshaking example. Basically, I'm working with Visual C++ and trying to implement continuous digital data logging using double buffering and burst mode handshaking, but I'm not sure how to go about it. Any suggest
ions??? Please Help...
(3,771 Views)
My suggestion would be to download the January 2001 version of the 653x User Manual. This manual has some block diagrams that show how to use NI-DAQ to perform different digital operations. The manual may be downloaded at www.ni.com/manuals.
As for your questions about the DIdoubleBufHandshake653x.c example, I'm not exactly sure what is going on. I think the comments may be a little loose- although the example is a handshaking example, the term double-buffered pattern generation probably just means buffering is used and there is digital data being generated, but not that the mode is pattern generation mode.
Also, burst mode is not a handshaking mode. As you'll find out in the User Manual, you can perform handshaking or burst mode, but not both.
I hope this clarifies s
ome things.
(3,771 Views)
