Measurement Studio for VC++
NiGraph OLE error
I want to display a dialog box with a NiGraph but when i do a ""DoModal" the box does not appear and the fonction return -1 with these warnings:
OleInitialize returned scode = RPC_E_CHANGED_MODE ($80010106).
CreateDlgControls failed during dialog init.
Cwui.ocx is already registered.
Please help me!!
(3,510 Views)
That error typically occurs when you try to initialize COM in a thread in which COM is already initialized and you specify a different threading model than was specified the first time.
Are you explicitly calling CoInitializeEx somewhere else in the same thread? Are you using the Measurement Studio CNiGraph C++ class wrapper for the ActiveX control? If so, what version of Measurement Studio are you using?
(3,504 Views)
