Measurement Studio for VC++
Nidaq DLL could not be called due to interface error
I am attempting to access information from a module on a PXI-1000B chassis for the first time using the GetDAQDeviceInfo command (CWDaqTool). However I keep getting the response "Ni-daq DLL could not be called due to interface error". Any help would be greatly appreciated.
Rodney 😃
Here is my code:
// Trial1Dlg.cpp : implementation file
#include "stdafx.h"
#include "Trial1.h"
#include "Trial1Dlg.h"
#include "nidaq.h" // National Instruments Header File /
#include "nidaqcns.h" // National Instruments Header File /
#include "nidaqerr.h" // National Instruments Header File /
#include "nidaqex.h" // National Instruments Header File /
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CAboutDlg dialog used for App About
class CAboutDlg : public CDialog
public:
CAboutDlg();
// Dialog Data
//{{AFX_DATA(CAboutDlg)
enum { IDD = IDD_ABOUTBOX };
//}}AFX_DATA
// ClassWizard generated virtual function overrides
//{{AFX_VIRTUAL(CAboutDlg)
protected:
virtual void DoDataExchange(CDataExchange* pDX); // DDX/DDV support
//}}AFX_VIRTUAL
// Implementation
protected:
//{{AFX_MSG(CAboutDlg)
//}}AFX_MSG
DECLARE_MESSAGE_MAP()
CAboutDlg::CAboutDlg() : CDialog(CAboutDlg::IDD)
//{{AFX_DATA_INIT(CAboutDlg)
//}}AFX_DATA_INIT
void CAboutDlg::DoDataExchange(CDataExchange* pDX)
CDialog::DoDataExchange(pDX);
//{{AFX_DATA_MAP(CAboutDlg)
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CAboutDlg, CDialog)
//{{AFX_MSG_MAP(CAboutDlg)
// No message handlers
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CTrial1Dlg dialog
CTrial1Dlg::CTrial1Dlg(CWnd* pParent /*=NULL*/)
: CDialog(CTrial1Dlg::IDD, pParent)
//{{AFX_DATA_INIT(CTrial1Dlg)
// NOTE: the ClassWizard will add member initialization here
//}}AFX_DATA_INIT
// Note that LoadIcon does not require a subsequent DestroyIcon in Win32
m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
void CTrial1Dlg::DoDataExchange(CDataExchange* pDX)
//{{AFX_DATA_MAP(CTrial1Dlg)
DDX_Control(pDX, IDC_CWDAQTOOLS1, m_CWDaqTools);
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CTrial1Dlg, CDialog)
//{{AFX_MSG_MAP(CTrial1Dlg)
ON_WM_SYSCOMMAND()
ON_WM_PAINT()
ON_WM_QUERYDRAGICON()
ON_BN_CLICKED(IDC_GETINFO, OnGetinfo)
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CTrial1Dlg message handlers
BOOL CTrial1Dlg::OnInitDialog()
CDialog::OnInitDialog();
// Add "About..." menu item to system menu.
// IDM_ABOUTBOX must be in the system command range.
ASSERT((IDM_ABOUTBOX & 0xFFF0) == IDM_ABOUTBOX);
ASSERT(IDM_ABOUTBOX < 0xF000);
CMenu* pSysMenu = GetSystemMenu(FALSE);
if (pSysMenu != NULL)
CString strAboutMenu;
strAboutMenu.LoadString(IDS_ABOUTBOX);
if (!strAboutMenu.IsEmpty())
pSysMenu->AppendMenu(MF_SEPARATOR);
pSysMenu->AppendMenu(MF_STRING, IDM_ABOUTBOX, strAboutMenu);
// Set the icon for this dialog. The framework does this automatically
// when the application's main window is not a dialog
SetIcon(m_hIcon, TRUE); // Set big icon
SetIcon(m_hIcon, FALSE); // Set small icon
// TODO: Add extra initialization here
return TRUE; // return TRUE unless you set the focus to a control
void CTrial1Dlg::OnSysCommand(UINT nID, LPARAM lParam)
if ((nID & 0xFFF0) == IDM_ABOUTBOX)
CAboutDlg dlgAbout;
dlgAbout.DoModal();
else
CDialog::OnSysCommand(nID, lParam);
// If you add a minimize button to your dialog, you will need the code below
// to draw the icon. For MFC applications using the document/view model,
// this is automatically done for you by the framework.
void CTrial1Dlg::OnPaint()
if (IsIconic())
CPaintDC dc(this); // device context for painting
SendMessage(WM_ICONERASEBKGND, (WPARAM) dc.GetSafeHdc(), 0);
// Center icon in client rectangle
int cxIcon = GetSystemMetrics(SM_CXICON);
int cyIcon = GetSystemMetrics(SM_CYICON);
CRect rect;
GetClientRect(&rect);
int x = (rect.Width() - cxIcon + 1) / 2;
int y = (rect.Height() - cyIcon + 1) / 2;
// Draw the icon
dc.DrawIcon(x, y, m_hIcon);
else
CDialog::OnPaint();
// The system calls this to obtain the cursor to display while the user drags
// the minimized window.
HCURSOR CTrial1Dlg::OnQueryDragIcon()
return (HCURSOR) m_hIcon;
#include "cwdaqtools.h"
void CTrial1Dlg::OnGetinfo()
COleVariant Info;
long Status;
long DeviceNumber = 1;
long InfoType = ND_DEVICE_NAME;
// Get information on the chassis
Status = m_CWDaqTools.GetDAQDeviceInfo(DeviceNumber, InfoType, Info);
(5,596 Views)
Hi Rodney,
I believe what is happening is that you are using the NI-DAQ InfoTypes rather than the ComponentWorks InfoTypes. The one you want is probably cwGetDeviceName.
I will include at the bottom of this posting a list of the ComponentWorks InfoTypes.
I got the list of types (on my computer at least) from:
start->programs->National Instruments->MeasurementStudio->Help->Measurement Studio Reference
That help file is part of Measurement Studio 6, so if you are using Measurement Studio 1 you will need to use the reference included with that.
I hope this is what you are looking for.
Sincerely,
John N
You can use the following constants with this data type:
cwGetAITransferMode–Data transfer mod
e for analog input
cwGetAOGroup1TransferMode–Data transfer mode for analog output Group 1
cwGetAOGroup2TransferMode–Data transfer mode for analog output Group 2
cwGetBaseAddress–Base address
cwGetComputerName–Computer name
cwGetCounterType–Counter type.
cwGetDAQCard700CounterSource–DAQCard-700 counter source
cwGetDeviceName–Device name
cwGetDeviceTypeCode–Device type code
cwGetDIOGroup1TransferMode–Data transfer mode for digital I/O Group 1
cwGetDIOGroup2TransferMode–Data transfer mode for digital I/O Group 2
cwGetDMAALevel–DMA A level
cwGetDMABLevel–DMA B level
cwGetDMACLevel–DMA C level
cwGetGPCTR0TransferMode–Data transfer mode for GPCTR 0
cwGetGPCTR1TransferMode–Data transfer mode for GPCTR 1
cwGetInterruptALevel–Interrupts A level.
cwGetInterruptBLevel–Interrupts B level.
cwGetInterruptGenerationMode–Interrupts generation mode.
cwGetLPTD
eviceMode–LPT device mode
cwGetNIDAQVersion–NI-DAQ version
cwGetSerialNumber–Serial number.
cwGetSuspendDeviceState–Device state during suspend mode
(5,596 Views)
Thanks for the heads up John, but there is one catch here. The NI-DAQ InfoTypes, such as 'cwGetDeviceName' are stored in the 'nidaqcns.h' header file, but where are the ComponentWorks InfoTypes stored??? I can't use them without including the proper header file.
Do you know of any examples which retrieve information using the ComponentWorks InfoTypes???
(5,596 Views)
Never mind John, I understand what you meant. I found the correct component works infotypes. Thank you for you help. It is appreciated.
Rodney 😃
(5,596 Views)
You didn't say what OS you were using, but this sounds like a known issues with NI-DAQ and Visual Studio under Windows 2000. There is a DLL base address problem that hinders loading some DLL's with 6.8.1 and 6.9.0 of NI-DAQ under Windows 2000. There is a knowledgebase article with a patch that should fix it here: http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/6b75ca1982574cb7862569ae00784fff?OpenDocument.
If this does NOT fix it, contact our tech support staff at http://www.ni.com/ask and we'll help you with it.
Best Regards,
Chris Matthews
(5,595 Views)
There was a post by Chris Matthews National Instruments, indicating a knowledge base article with a patch:
However, this link now returns a messge: "You are not authorized to view this document"
I am doing a minor update for a past project, but I can not complete compiling due to this interface error.
OS is Windows 2000, VB6, Measurement studio
Thanks in advance!
(3,943 Views)
