Measurement Studio for VC++
Cont Gen Volt Wfm-Ext Clk-Dig Start Example
I use Cont Gen Volt Wfm-Ext Clk-Dig Start project in VS 2013 pro, to test, but the output on my meter is 0 volt. my question is simple: What I need to do to to make this example work? I use aoO as in example. No errors. When I use Ni MAX - > Test Panels -> Analog Output -> Change output value - it is working, but not with this example..
Thank you
(5,359 Views)
hello OlgaYurina,
what hardware are you using? what lines did you configure as the trigger and timer source?
(5,344 Views)
