Measurement Studio for VC++
offset problem : DAQmxPerformBridgeOffsetNullingCalEx
Hello All,
I have an problem of OFFSET .
I explain:
I use 2 NI cDAQ-9178
Test 1:
A module 9213 is plugged on 1 NI cDAQ-9178
A module 9237 is plugged on 1 NI cDAQ-9178
If I call the function : DAQmxPerformBridgeOffsetNullingCalEx  for the module 9237, there is no problem this function returns 0.
Test 2:
The two modules 9213 and 9237 are plugged on the same NI cDAQ-9178.
If I call the function : DAQmxPerformBridgeOffsetNullingCalEx  for the module 9237, the function returns -200478
Why........
I dont understand why I get this error.
Thanks for your responses.
(5,816 Views)
Hi Laurent,
Which DAQmx driver version are you using?
It seems that the behavior you have was an unexpected one:
Error -200478 occurs when using DAQmx Perform Bridge Offset Nulling Calibration with AI.Temp.TC and ...
Neverthless, it was corrected in DAQmx 9.6 (see CAR 345144):
DAQmx 9.6 Readme
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
(5,804 Views)
Hi Valentin,
Thanks for your response.
The driver used : 9.1
I will download the last version and I will try
Best regards
(5,800 Views)
