Measurement Studio for VC++
PCI-6025E TO USB-6218 OEM
Hello?
I'm working on code converting work from PCI-6025E to USB-6218 OEM. The source code was written for PCI-6025E. This must be re-written for USB-6218 OEM.
I wonder whether DAQmx 8.7.1 supports USB-6218 OEM for Visual C++ 6.0
And how can I convert it for USB-6218 OEM?
Is additional function like HIdD_GetHidGuid() required to hook the USB driver?
I'm converting DAQ to DAQmx..from Parkoz.com
(6,804 Views)
Hello anarkie,
The DAQmx 8.7.1 driver supports the USB-6218 OEM DAQ device.  The driver also provides the capability to transfer data over the USB bus,
so no additional functions such as the HIdD_GetHidGuid() would be required.  To convert your Visual C++ code to work with the USB-6218, you
must first install the new DAQ device and make sure that your code reflects the device name of the USB-6218 OEM.  You must also make sure
that parameters, such as sampling rate, are appropriate for the USB-6218 OEM.
Best wishes,
Wallace F.
(6,774 Views)
Oh, thanks so much!
I was wondering why no one answered! Thanks man!
(6,762 Views)
