my application allows me to browse my system for all existing NI-Devices.
If I add a new device such as the USB 9233, I ask the device for its maximum sample rate and number of possible channels to display the information for the user. The user can then specify his needed channels etc. I get the information by creating a task for that device and reading the channelinfo.
When I'm now connecting the cDAQ Chassis 9172 with the system I 'm facing some errors. I have a 9233 and a 9215 plugged in the 9172.
I can read information from the 9215 but I get 235294 S/s as a maximum sample rate? Can this be right?
I can't read any information from the 9233 and get an error message in the eventviewer:
Error: -201087
Description: Measurements: Task contains physical channels on one or more devices that require you to specify the Sample Clock Rate.
Specify a Sample Clock Rate.
Device: cDAQ1
I don't know which sample clock I have to specify.
What are the differences when I#m working with the USB 9233 and the 9233 plugged in an 9172 Chassis?
Thank you for your help.
Karsten
