Measurement Studio for VC++
error using dispose function
Hi all,
I'm having a problem, and i will try to explain it here, hope anyone can help me any further.
I'm developing a program with the microsoft visual C++ express edition (version 2005).
in my application, i would like to be able to make a connection to a device by TCPIP (ethernet) and when i push a button, i want to close the connection. the first thing, making a connection, works, but when i try to close the messagebasedsession
(by using mbSession->Dispose(); ) i get an error:
Error 1 error C2039: 'Dispose' : is not a member of 'NationalInstruments::VisaNS::MessageBasedSession' c:\hirschmann\visual c++\fsl communication\Form1.h 328
anyone knows how i should fix this ?
Greatings, Hans
(7,685 Views)
*kick*
does anyone know what I'm doing wrong?
the error occurures when i use this command:
(7,647 Views)
Hi Hanzz,
See the following document on the Microsoft MSDN Library regarding this Compiler error:
At the bottem of this document it indicates the same error you are having with the Dispose function. You could replace the:
with
delete mbSession;
This will also dispose the object, if it was create with the object with new / gcnew.
Hope this helps,
Regards
Karsten
Message Edited by KvZ on 10-24-2007 10:08 AM
(7,635 Views)
