Measurement Studio for VC++
Puzzled by passing array from VB6 to vc++
Problem setup:
I'm using a NI1430 board to grab images from a 12-bit ccd camera in a VB6 application.
After an image is obtained, I call
                     CWIMAQImage.ImageToArray()
to get the data, and pass it on to a VC++ dll to do some processing.
The C++ function looks like this:
                          STDMETHODIMP Cmath::centroid(VARIANT *image, short width, short height, ... VARIANT *theCentroid)
where the first parameter, VARIANT *image, is the data array.
Problem:
I have a frame grabber from a different company.  They provide a method to extract the data array as well, something like: ImageClass.getImageData().
When I pass the the data arrays from the different boards to my C++ routine, the array from NI runs 10 times slower than the other one.
The arrays look identical on the VB6 side - they are both integer arrays of the same size.
When I inspect the data  passed in on the C++ side.  It turns out that
for the NI 1430 board,
           image -> vt == 0x2002,  indicating the data coming in is truely an array of integers
while for my other board,
         image ->vt == 0x6002, indicating the data are passed in as a reference to an array of integers.
I believe this is where the 10x difference in processing speed originates
Questions:
I'm puzzled by how two identical arrays from the VB6 side are passed into C++ so differently.  There is no intermediate step between getting the array on the VB6 side and calling the VC++ routine.
How can I pass the data array from the NI board (CWIMAQImage.ImageToArray()) by reference rather than by value to the C++ routine?
Thank you so much for your insight.  I've been struggling with this problem for quite sometime ...
(5,683 Views)
Have you looked through the help file for the Vision Acquisition Software for textbase functions? It can be found at C:\Program Files\National Instruments\Vision\Documentation. Here you can find a list of functions available.
Cameron T
(5,667 Views)
