Measurement Studio for VC++
help
hello everybody please I need to know how  can I make use of Ni USB-6259 and how to handle interfaces using C + + because even though my code (in visual studio) compiles correctly I ignore the command that must set for this device in the catalogs they notice :
This initializes the instrument with the Following parameters:
Ag34401_InitWithOptions
("GPIB::23::INSTR",VI_FALSE, VI_TRUE,"Simulate = 1", &session)
GPIB0 :: 23 :: INSTR is the Resource Name (GPIB instrument at address 23).
I want to know the procedure for this equipment.that's mean the equivalent and how to write the total adresse for any Pin
Thank you so much
(5,611 Views)
Hi yosh-over,
In other to use your DAQ Card with Visual Studio, you'll need to install DAQmx Driver and then add the Text Based support.
Also, please check to this link.
Best,
Carmen C.
(5,600 Views)
