Measurement Studio for VC++
Simultaniously Input / Output
i tried to Output an analog signal and read it simultaneously with  Borland C++ Builder 6.0 and a NI-DAQ 6115 Card.
That is the code I’m using:
/*/ DAQmx Configure Code
/*SEND OUTPUT*/
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",sampleRate,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,transcount));
/*READ AI0*/
DAQmxErrChk (DAQmxCreateTask("",&taskHandle1));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle1,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle1,"",100,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,1000));
/*/ DAQmx Write Code
DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,voltageOutput,&written,NULL));
/*/ DAQmx Read Code
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle1,10000,10.0,DAQmx_Val_GroupByChannel,input1,10000,&read,NULL));
/*/ DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle1));
DAQmxErrChk (DAQmxStartTask(taskHandle));
(3,299 Views)
second part
/*/ DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
DAQmxStopTask(taskHandle1);
DAQmxClearTask(taskHandle1);
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
 /*/ DAQmx Stop Code
      if( DAQmxFailed(error) ){
            Application->MessageBoxA(("DAQmx Error: %s\n",errBuff),"ERROR");
                errorLog = true;
  for(int i = 0; i < 1000; i++){
   asLine += input1[i];
asLine += ";";
asLine += "\n";
But somehow I don’t get the input I expected. Have You any idea how I can solve this problem?
Thanks in advance
(3,297 Views)
