Measurement Studio for VC++
Stand-alone MeasurementStutio DLL
is it possible to create a 'stand-alone' dll for a specific device like DIO-96 or other?
stand-alone which i mean that without installing National Instrument Driver Software the one with MAX.
(3,960 Views)
Hello kerby,
Short of creating your own driver using RLP programming, no.  You will need to install NI-DAQ to be able to communicate with your DAQ device.
I hope this helps.  Please let me know if you have any further questions.
Sean C.
(3,944 Views)
Register-Level programming might be the solution, can you give me some hints...
on the other hand i've tried Jungo Windriver 7(driver creator software)for  PCII-DIO-96...
but still no progress/.
(3,935 Views)
Hello kerby,
After looking into this a little more, I discovered that National Instruments does not support RLP programming for the PCI-DIO-96, so that is not an option.  If you had one of the supported Digital I/O boards (NI PCI-650x & PXI-650x, NI PCI-6533 & PXI-6533), this would be possible.  Why is it that you cannot install NI-DAQ?
Sean C.
(3,916 Views)
actually i am using a Dll to control the Read/Write functionality of the board, i made that Dll using Measurement Studio for MSVC++ .NET2003.
And sometimes when i access such functionality my Client Application pause for a while (maybe the DLL start DAQ tasks). It may be Ok if im using my board as DAQ for instance.
But unfortunately i use it for Clocking and data_transfer.  A simulated clock in one pin of the device (hehe) about 0.01 ms wide.
but i am thinking now that the problem i had faced was not the Dll not NiDAQDriverSoftware but rather the client application which is built on Visual basic.
because when i did the same chore to c++ and see the results (of the clock) its much accurate than when i use VB.
anyways RLP is not a good idea anyway since there's an available driver already ^^
(3,909 Views)
