Home
Community
Discussion Forums
Most Active Software Boards
Measurement Studio for VC++
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
To Brian
To Brian
SMN
Member
11-27-2001
01:20 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Thanks, I already did that, but the problem is, that I get always a different measure result. I really don`t know what the problem is.
Stefan
0
Kudos
Message
1
of 3
(3,529 Views)
Reply
Re: To Brian
bman
Active Participant
11-28-2001
02:25 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Stefan
Try this example program. Connect the signal you are trying to measure to the Source of counter 0.
This should work. If it does not, there may be a problem with your NI-DAQ driver and we would need to reinstall the newest one.
B
freq_measurement_cw.zip 3 KB
0
Kudos
Message
2
of 3
(3,529 Views)
Reply
Re: To Brian
Grant_LECO
Member
11-29-2001
01:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Are they the same case?
Grant M. Johnson
Project Engineer
LECO Corporation
0
Kudos
Message
3
of 3
(3,529 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
