Measurement Studio for VC++
Upgrde NI-488.2 device driver
I'm currently running NI device driver 2.73 on my Windows 7 system.  I'd like to update the device driver to the latest-and-greatest NI-488.2 (version 3.0.2 I think).  Can I just install the new device driver or do I need to uninstall the old NI stuff first?
Thanks, Mike
(9,057 Views)
Hey Mike_D,
You can simply install the newest NI 488.2 device driver (3.0.2) without uninstalling the older one.
Wear
Product Support Engineer
(9,048 Views)
Hi Wear,
Thanks for the quick response.  I installed the NI-488.2 3.0.2 package on my Win7 system and everything seemed to install OK.
But, now when I run MAX 5.1 and look at my (only) GPIB-USB-HS device MAX tells me that "GPIB interface properties can only be changed by an Administrator".  I am an Administrator but all the settings are still disabled.  What do I do now?
Mike
(9,040 Views)
Hey Mike,
You can right click on the icon for Measurement and Automation Explorer and select “Run as Administrator” and that will run the program with the appropriate privileges.
Wear
(9,031 Views)
Accepted by Mike_D.
Done and done.  I wasn't sure if there was a setting in MAX to do this.  Thanks for your help.  Let's consider this topic 'closed'.
(9,025 Views)
