Measurement Studio for VC++
Variant array
Does anyone know how to create a VARIANT array in Visual C++? The following parameter is part of the FillImage2 method and I'm having trouble creating a 1D array of type Variant. Any insight will be appreciated!
RGBU64 As Variant
[Optional] A 1D array with 4 integer elements (the red, green, blue, and alpha planes) used to fill RGBU64 images.
(3,454 Views)
Looks like you need a VARIANT that contains a SAFEARRAY. Try this
int data[4]= {1,2,3,4};
COleSafeArray sa;
//Populate SafeArray with an array of int
sa.CreateOneDim(VT_I4, 4, data);
VARIANT* myVariant = ((LPVARIANT)sa);
Im assuming you have MFC support in your project. For more information, refer to the ColeSafeArray help on the MSDN.
Hope this helps
Bilal Durrani
NI
(3,439 Views)
