Measurement Studio for VC++
What does Sigle Cycle Timed Loop mean?
What does Sigle Cycle Timed Loop architecture mean?If I have a sequence structure in my program does it get completed before 25 ns or the entire program itself gets completed in 25ns?Thanks in advance!
Waran
(3,726 Views)
Hello
This is the Measurement Studio forum. You will get a better answer if you post to the LabVIEW Targets forum.
Bilal Durrani
NI
Bilal Durrani
NI
(3,726 Views)
Hi Waran,
The single-cycle timed loop (SCTL) is a special case of the new LabVIEW timed loop structure. It is available in version 7.1 of LabVIEW FPGA ModuleThis loop executes all functions inside it within one 25 nsec �tick� of the 40 MHz global clock.
If you are writing you code to be compiled and run on an NI-RIO target, and if the functions that you use are able to be executed in one tick, all of your code in the loop should be executed in 25ns.
I hope that this helps.
P.J.
National Instruments - FPGA Applications Engineer
(3,726 Views)
