Measurement Studio for VC++
Why do i have an image of my points on the X axis ?
Hi
I use a CCWGraph, on which i have some points. My problem is that each point has his "image" drawn on the X axis. How can i make these points disappear ?
(4,535 Views)
Manu:
I'm not quite sure what you mean by points having an "image" on the X-Axis. If you would like to plot something without the points being shown, then you can set the "Point style" to "None" under the "Plots" tab.
If you're having some problems with the actual rendering of the control (i.e. the control is drawing on the X-Axis), then I would suggest that you contact our e-mail or phone support to continue this discussion. You can reach our email support at http://www.ni.com/ask or our phone support at 1-800-IEEE-488.
Good Luck!
Chris Wood
(4,535 Views)
