Measurement Studio for VC++
copy NIVector to double array
is there an easy way to copy data from an CNIReal64Vector to a double array?
I tried to use the STL copy algorithm, but the tricky thing is that I have to copy the last element myself. Ugly...
The method gets a pointer to an array : double* autoSpectrum1[]
CNiReal64Vector niAutoSpectrum;
MathError errorNI = CNiMath::AutoPowerSpectrum(timeDataVector, niAutoSpectrum, df, dt);
size = niAutoSpectrum.GetSize();
*autoSpectrum1 = new double[size];
std::copy(&niAutoSpectrum[0], &niAutoSpectrum[size-1], &(*autoSpectrum1)[0]);
(*autoSpectrum1)[size-1] = niAutoSpectrum[size-1];
Any idea?
 Mario
(5,263 Views)
Hi Mario,
Here your "double* autoSpectrum1[]" is a table of pointer.
When you have, you can do is to do a "For Loop" and copy the element of the table pointed from your "autoSpectrum1" table and save it in a 2D table...
I think that is the best way to do that...
Regards...
Matthieu
(5,260 Views)
