Measurement Studio for VC++
correlate function
Hi Gurus, I am using the correlate function to correlate to vectors of type CNiReal64, to test if the returned corrolation vector was right I inputed, to identical vectors. I was expected to have a single value of one returned... Instead I have 3.5*10-63....
I paste my code where array1 is input 1, array2 is input2 and correl is output..
Do you see anything wrong???
double *array1 = new double[nbrSamples];
double *array2 = new double[nbrSamples];
double correl[1];
CNiMath :: Correlate(CNiReal64Vector(nbrSamples,array1),CNiReal64Vector(nbrSamples,array2),
CNiReal64Vector(1,correl));
char swap[10];
sprintf(swap,"%g",correl[0])/*(double)sumcorrel/(double)nbrSegments)*/;
AfxMessageBox(swap);
(3,340 Views)
Hello
One thing that sticks out is the way you are returning Rxy from the correlate function. The way you have it right now,the CniReal64Vector is making a copy of correl, and the actual value of Rxy is returned in a variable that exist temporarily on the stack. You should have some like
CNiReal64Vector Rxy(1,0.0);
CNiMath::Correlate(CNiReal64Vector (4,0.0),CNiReal64Vector (4,0.0),Rxy);
Now Rxy is be the vector containg the Correlation data of the input arrays
And I think the documentation is incorrect. The size of the return array is actaully m+n-1. I will file a CAR about this though.
I hope this helps
Let me know if I missed anything
Bilal Durrani
NI
Bilal Durrani
NI
(3,340 Views)
