Measurement Studio for VC++
digital waveform - extracting lines 0-7
I am having trouble stripping out the sepearte line from a 9401 cdaq card in  DAQ-9172 chassis. I have attached the vi I am using and can get the seperate line to display on a graph but can't strip each one out. I want to run each line through a dac and use single tone on the analog waveform to get the frequency of each.
(6,413 Views)
Simply use the index Waveform.vi function.  you wire in the array of waveforms that comes out of the DAQmx Read and specify a given index (whether you want the first, second third waveform) and the output is a single waveform corresponding to the channel you specified.
This function can be found: Functions >> Programming>> Waveform >>Index Wameforms.vi
Please see attached VI to see how this can be implemented.
Thank you
Charley Dahan
Global Account Manager
(6,401 Views)
Thanks but that doesn't work. It still does the same as my original. All lines come out on waveform 0. They all show up in the first index. I want to strip out any of the 8 lines from the waveform.
(6,397 Views)
