Measurement Studio for VC++
how to add a scroll bar within a view window ?I want to display x and y axis outside the scoll window and keep those axis static and move the graph within scroll area
ananya
(3,464 Views)
Hey Ananya,
I believe what you want to do is possible, but it will not be easy.  If you want to add a scroll bar that will scroll the graph back and forth but keep the axis set, you would want to add a horizontal or vertical scrollbar.  Then you would create an event handler for the scroll event.  You would have to manually plot different data within this scroll event.  Unfortunately, there is not really a built in way to do this with the Measurement Studio plot control.
Pat P.
Software Engineer
(3,458 Views)
