Measurement Studio for VC++
how to calculate area under the waveform
I need to calculate absolute energy of the waveform. Do you have a math function to do this? I used Integrate funtion but the return value is 0.
(3,707 Views)
You didn't say much about what you are doing. The CNiMath::Integrate function should be able to do this for you. Maybe you don't understand the function. You would input your waveform as a vector (say 1000 elements), then the delta time between each element (1/sampling rate), then the first and last value of the discrete integral (waveform[-1] and waveform[n]). Then, on output, the vector would contain the integrated data. You could get the sum of the elements to get the total area under the curve.
Best Regards,
Chris Matthews
(3,707 Views)
