You didn't say much about what you are doing. The CNiMath::Integrate function should be able to do this for you. Maybe you don't understand the function. You would input your waveform as a vector (say 1000 elements), then the delta time between each element (1/sampling rate), then the first and last value of the discrete integral (waveform[-1] and waveform[n]). Then, on output, the vector would contain the integrated data. You could get the sum of the elements to get the total area under the curve.
Best Regards,
Chris Matthews
