Measurement Studio for VC++
how to use Counter B0 and B1 in the same time
Hi, I am a rookie, and first time post question at here.
my Card is DAQcard-1200, and data acquisition code is based on MFC of VC6. now I used counter B0 as timer for data sample. how can i use B1 as a suqare wave generator?
Thank you.
(3,560 Views)
Hello PhilaNI,
Checkout this post.
(3,547 Views)
Hi, Sergesl.
Thanks for your answer and help.
Could you tell me how to do it. I am a newbie here.
(3,543 Views)
Hello P.
The post says that you cannot setup a squarewave generator using B1 unless you provide an external clock; which would not make any sense since you are trying to generate a clock signal. But if you use B0, then the first thing I would advise you to do is read the general purpose timing section of the manual.
I would then search National Instruments' web site for examples such as this one. You can search for examples in the NI Developer Zone.
Message Edited by sergesl on 06-29-2005 02:05 AM
(3,522 Views)
