Measurement Studio for VC++
need example for digital trigger in ms c for the pci 6024e
are there any examples in ms c for useing external
digital trigger to initiate analog in sampling
on the pci 6024e board the documentation on the
select_signal functions have me confused
I tried the DaqSingleBufExtTrig-ESeries.c
example with out any luck I am not sure if the
functions in that example pertain to my pci 6024E
bord or if I maybe did not apply the correct ttl
digital signal to the pfi0/TRIG1 If any one has
experience programing this board in ms c useing the
NI_DAQ functions i would deeply appreciate some help
bertleeman@hotmail.com
(3,094 Views)
Walter;
I'm attaching a example code performing the task you need. Also, make sure the digital trigger is meeting the TTL requirements as far as rising time and period.
Hope this helps.
Filipe
(3,094 Views)
