Measurement Studio for VC++
plot spectrum vs time
I want to create a plot which show spectrum vs. time. Instead of a waterfall plot, I would like to have two axis:
- x: time
- y: frequency
The frequency axis will have 100 points. Each point represents the strength of the frequency in color (or I may use grayscale). For example:
- red: large amplitude
- orange: medium amplitude
- white: low amplitude
The graph will automatically scroll to the left as new data is added as a vertical column on colors. In this way, I can see how the frequency content changes over time.
Can this be done? I am using MS Visual Studio 6.0 C++. I have used  ChartXY and PlotXY for plotting a single spectrum, and for other time based data.
Thanks!
(6,448 Views)
Hi Bbuternowsky,
One way you could accomplish this would be to use a 3d graph control with the view set to be directly down the z axis.  You can then assign a gradient to the z axis to obtain your z coloring.  There are a number of examples showing the 3d graphing functionality of Measurement Studio:
 C:\Documents and Settings\All Users\Documents\National Instruments\MStudioVS2008\VCNET\Examples\UI\3DGraph
The color map styles example in this folder demonstrates configuration of the z axis coloring, so that would be a good place to start!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(6,432 Views)
