Hallo,
I never programmed a DAQ before. I read the examples and searched the forum but I don´t understand the examples complete and now I don´t know how to begin.
I need to program a DAQ Card E6036 in C++ which gets three input signals (voltage -10/+10V) and then outputs the data (separate) as a digital signal in the memory. So I want to ask if somebody has had the same problem and can give me a short example or links on the NI- Homepage of how to do this.
I add a short list of specifications
- The sampling rate has to be 1kHz or higher
- I have to integrate the program later as *.dll in Labview
If there are more questions i will answer them and I hope this is the right forum.
best regards
Werner
