Hi Jim
Are you using Measurement Studio 6.0 with the CWGraph?  If so, you
can right-click on the graph and select "Properties".  On the
"Ticks" tab, select "Y-axis" from the drop down menu.  In the
"Labels" section, put a check next to "Right".  That should put
the axis on the right-hand side.
Hope this helps!
Russell G.
NI Applications Engineering
